What is likely to burn out?
ulms
Joined Mar 19, 2024
179
I have 5 volts supplied by a phone charger. Some green and red LEDs some 2n222 transistors and a 555 timer. While powered up a slip with the meter probe and everything has stopped working. One LED might light up. What is likely to fry instantaneously, any ideas thanks
BobTPH
Joined Jun 5, 2013
11,643
Which single part would cause all the failures if removed from the circuit? That is what I would check first. Of course it might also be multiple parts.
ulms
Joined Mar 19, 2024
179
I have 5 volts supplied by a phone charger. Some green and red LEDs some 2n222 transistors and a 555 timer. While powered up a slip with the meter probe and everything has stopped working. One LED might light up. What is likely to fry instantaneously, any ideas, thanks. Also the dmm was set to check current.
Hello guys thanks for all the input. I was looking for what might be likely to fry instantaneously by a misplaced dmm probe. I have wired 555 timers so poorly they got so hot you could fry eggs on them and they would still work. I've put transistors in backwards and they still work. I'm about to go component by component I was just wondering if something is a notorious weak link. Thanks again
dl324
Joined Mar 30, 2015
18,457
If you leave them in that condition long enough, junctions will start melting.
Are you sure they still work? If you breakdown the base-emitter junction, current gain can be damaged.
Just troubleshoot the problem instead of guessing.
If you ask for help, you should post a schematic so we know what you're dealing with. If you don't know what you're doing, add voltage measurements for important nodes.
28,206
Here is an analysis based on a guess that the transistor controlled the LEDs that no longer light, and that the probe short circuited some device..
1.) if the probe connected the two leads of an LED to each other, and the transistor had been passing some current to light the LED, then the guess is that the transistor suddenly had five volts, emitter to collector, while switched on. So it would quickly overheat and fail. Or the slip applied 5 volts between the base and emitter, and fried that junction. If that also caused a collector to emitter short inside, then the 5 volts across the LEDs could fail them in a very short time.
If the connection was on the 555 pins, and the +5 applied to the output pin while it was active, the output transistor in the 555 may be failed.
Consider that those guesses are based on no hint as to where the probe was whan it slipped, and no circuit information.
ulms
Joined Mar 19, 2024
179
Thank you, it was a transistor!
