Current plan is gravity drop, cable/chain pullout, rack or ratchet locking.
This allows a varying lower lock point.
Possible lift drive specs are: 100 lbf pull, 0.2 m/s, about 60rpm at 60mm sprocket diameter.
that is about 460 N, and 460 x 0.2 = 92 W, say 100 Watts?
"Official" winches start in about 1000 lbf, so I need to source a separate clutch unit.
Something that fits on to the gearbox output shaft in-line with the output sprocket would be good.
Output torque is about F x r = 460 N x .03 m = 14 N-m (10.3 ft-lb)
shaft diameter should be around 8mm ? The RobotShop units usually have a "D" form,
with a drive flat.
Any ideas where I can find a nice clutch design or an actual product?
Not having a lathe, I can't make things that require "turning" for now.
It doesn't need a lot of "dog" teeth.
The motor /sprocket shaft extension can be supported by an outrigger bearing.
The clutch needs an inner sleeve or spigot bearing, to locate the output sprocket.
Next: look for a ratchet linear brake/lock?- a small rotary friction brake
usually doesn't have the required torque grip. (to hold the 1200 lbf linear force,
maybe run by chain over 100mm sprockets. - 1 turn= full travel,
torque (5500 N), x 0.05 m = 275 N-m
This would need about a 20mm shaft.
with a drive flat.
