I think I'm close to an answer to passively charging my batteries. I purchased 4 of these https://www.batteryspace.com/balanc...b03mu-jyy3hqqzzpuwqbqs1othz-iskiaaidgealw_wcb And added a 50W 1 ohm Aluminum housed wirewound resistor to each. As my packs started to reach their max charge, I connected to the pack with the highest voltage, (Just over 14.4 volts). It did limit the charge to that pack as the other packs caught up. The boards I purchased were deigned to dissipate 1.4 amps. However, by adding the new resistor they now can handle 15 amps. My concern is weather the rest of the components on the board will hold up. (Picture below of 4 of the boards and 4 additional resistors)
So obviously these boards have what I've been looking for. A switch that connects the resistors at around 3.6 volts and dumps the excess voltage/ amperage.
I plan to run this test board several times. I need to be sure about this because using this set up for all 26 modules will cost around $1100.00.
I have a very basic knowledge in electronics and I've spent way too much money so far.
Any help would be appreciated.
Thanks, Kevin
Thanks, Kevin
