library/algorithm/formula needed!
Eric007
Joined Aug 5, 2011
1,158
Hi All,
I would like to render something like attached, that is when move an image (bubble/circle) to one side of the screen (up, down, left or right) something like a wave/liquid/... appear, as attached, to that side of the screen.
Hope my description is not too vague but the image is more explanatory. I am not sure if I should study 2d physics or animation or... I need guidance, links,... to point me towards the right direction.
Thanks in advance.
Eric
John P
Joined Oct 14, 2008
2,061
Is this meant to be an animation? I just see a static image. Or maybe the posting indicates "I have a static image and I want to animate it".
Eric007
Joined Aug 5, 2011
1,158
Thanks Jhon for your reply!
I am currently reading on OpenGL ES to implement the above.
No it's not static! There are, if I may say, 2 objects. One that is visible and that can be move either by dragging or using direction and another one that only appear as a liquid or something when the 1st object is move to one side of the screen.
After reading I think I will be able to do the first part (drawing that bubble shape and moving it around) not sure yet about the second part.
Many Thanks
Eric
MrSoftware
Joined Oct 29, 2013
2,273
OpenGL or DirectX would both do the trick, but those are lower level API's. These are great if you want to write code yourself. If you just want to achieve the end goal, then look for a higher level animation tool.
Eric007
Joined Aug 5, 2011
1,158
I'm using OpenGL ES 2 and this is actually harder than I thought it'd be. Ima need more time to grasp all the concepts.
@MrSoftware Thanks for your input. What higher level animation tool you would suggest?
Btw I deleted the picture but can put it back if needed but I assume you all seen it.
I'm having a hard time right now.
Eric
MrSoftware
Joined Oct 29, 2013
2,273
I haven't worked in the computer graphics realm for some years now, I'm not sure what's out there these days. If you google computer animation tools, or computer simulation tools, etc.. then I'm sure you'll come up with a lot of reading to get started. The key is that you're looking for a tool to create animations with, you're not trying to invent a new tool yourself.
If you're just starting out and coding isn't your end goal, then jumping into OpenGL or DirectX at the API level is going to have a very steep learning curve. The higher level tools you find might use OpenGL, DirectX, etc.. under the hood.
Here are some links to get you started:
https://en.wikipedia.org/wiki/Computer_animation
https://en.wikipedia.org/wiki/Fluid_animation
Eric007
Joined Aug 5, 2011
1,158
What you do when they give you a task that looks impossible and there's a deadline? I said impossible I know the above is not impossible but I know you got what I mean...
mcgyvr
Joined Oct 15, 2009
5,394
I don't see the original image anymore..
But based on the details given (very few) maybe you could just accomplish your goal with CSS/Javascript animations..
Thats FAR easier than diving into OpenGL/DirectX,etc..
Eric007
Joined Aug 5, 2011
1,158
Btw, it's for an android mobile application.
Eric007
Joined Aug 5, 2011
1,158
I am hijacking my thread a bit...
I am looking for a good 'arial' font to apply to some text for one of my programs. The one I have making the text size smaller and bold (not cool). I just want it to change the default to arial.
Eric
Eric007
Joined Aug 5, 2011
1,158
Anybody knows how to export vertices of a 2d image/model? I did some google research and I found Blender...
