Hi !
I want to build a protection for the 3.6V Panasonic NCR18650B Li-ion cell, using the AP9101C chip. It has the following schematics...
But I don't understand how that duble mosfet switch works. From what I understand, when a MOSFET is OFF it conduct through its body diode in the reverse way. Lets imagine the followin scenario... The battery is charging and it enters in overcharge protection, so the Q2 will switch OFF. Now we start discharging the battery, while it has charging disabled. The curent from the battery plus (+) will go through load and reach the Q2 Source terminal. The MOSFET being OFF, the channel is blocked so the current will flow throug the body diode. Em I right ? But, I think that that diode isn't supposed to be used that way. So, how this schematics works if the only available path is through those diodes, but they are not supposed to by used in normal operation. I think somewhere is a misunderstanding...
