Li-Ion battery Cell Simulator Circuit design
alok_kumar
Joined Jul 16, 2024
8
Hi ,
For testing the BMS I want to design the 24-channel Li-ion battery cell simulator
In starting my thought was to use a potentiometer-based resistive divider network but facing problem of voltage geting chage if i chage resistance of one channel.
my requirment is to get voltage range form 2.8 to 4 in each channel individualy i want to change.
can any one suggest or Help me to design the circuit to simulate voltage sensing to BMS. 1721141759818.png
alok_kumar
Joined Jul 16, 2024
8
The why not use 24 voltage sources (V) in series?
That way each can be changed individually without affecting the others.
Actually I want to create 2.8v to 4v in each channel from 100v power supply
and one channel ground should be common to next channel positive terminal for BMS voltage sensing
and it not possible to arrange on bench level 24 voltage source
38,841
Okay, I thought you were talking about a simulation.
If you can adjust the 100V supply to generate a constant-current, then you can vary one resistor value without affecting the voltage drop across the other series resistors.
What supply are you using?
alok_kumar
Joined Jul 16, 2024
8
Exactly i want to vary one resistor without affecting other channel voltage
I am using EA variable DC-power supply with 10A current rating
would you suggest how can I design circuit? which can satisfy above consition.
38,841
2 I will use in series
Okay.
That makes a constant-current approach problematic.
So how about applying 96V to twenty-four 10k pots in series (below).
If you take the voltage from the wiper, then adjustment of that wiper position from 0 to 4V, won't affect the current or voltage of the other pots.
alok_kumar
Joined Jul 16, 2024
8
Okay.
yes we try this circuit in hardware but this create problem if I change one channel pot value it will change voltage value in other channel as well. we want to vary each channel voltage individually.
also BMS showing voltage value up to 3 digit (x.xxx) so we don't want variation in voltage after decimal point.
38,841
Not if you connect them as shown in post #12.
Unless there's a significant load on the pot wiper, the voltages on the other pots don't change if one pot voltage is changed.
In the LTspice sim below you can see that changing the voltage of the Ch2 pot wiper (yellow trace) has no effect on the other channel voltages.
alok_kumar
Joined Jul 16, 2024
8
we designed this in hardware in real time. We are not observing much change in the voltages of the far away channels from the channel we change.
If we change the Wiper-4 we are observing changes in wiper-3,wiper-5 dominantly, where as in all the other wipers the change is minimal.
And if we go for the wiper with larger resistance, we are unable to get a decently precise control over the voltages.
Danko
Joined Nov 22, 2017
2,238
Improved circuit:
1. Minus of PS V1 and minus of resistors chain are grounded.
2. Value of stabilized current increased from 0.4 mA to 2.5 mA, so values of chain resistors are decreased.
3. Eliminated influence of base current of Q1 on resistors chain current accuracy.
Ultimate deviation of channel voltage in process of manipulation:
When all resistors from U2 to U24 are in state T=0, then
-If state of U1=0 then voltage of channel 1 is 2.745491 V
-if state of U1=1 then voltage of channel 1 is 4.016416 V
When all resistors from U2 to U24 are in state T=1, then
-If state of U1=0 then voltage of channel 1 is 2.745482 V
-If state of U1=1 then voltage of channel 1 is 4.016406 V
Irving
Joined Jan 30, 2016
5,195
With that chain of pots, any reasonable current draw from wiper to next pot down will affect voltages at each pot... Its not simulating a stack of cells because in a cell stack the top of cell n is the bottom of cell n+1, whereas here the wiper of pot n isn't connected to the bottom of pot n+1.
