For some reason my 32 inch led tv has no backlight although it has sound and display (flashlight tested).
I opened it up and using some online guides I tested. The power supply which seems to be working fine.
I have a doubt about LED ground pad (I assume it's ground). Can you please tell me if the common ground and Led - ve pads are supposed to be same? See the attached picture please.
As I check voltage between Body (ground) and LED +, I get 100+ volts reading but when I check between LED - and LED +, I get 8 volts. I suspect there might be problem with LED - pad. Please correct me if I'm wrong. Thank you for your help.
