It is real. ----> https://www.audioholics.com/news/ascendo-100-sub-proI'll bite: Is that fun-with-AI, or something real? Reminds me of Disaster Area
Now that you mention it. We used shaker tables (vibration) for environmental testing and some we lowered a thermal chamber on. Vibe and thermal shock testing. Yep, a gigantic bass speaker.Reminds me of the shaker table in the environmental lab where I had a product tested. Top frequency was only about 2kHz. The base weighed about 5 tons and the top surface of the table was 4 ft square. We bolted our UUT to the table surface. Beneath the table was a magnet and coil setup similar to a large speaker. With its 3 phase 208 powered 33kW amplifier, it was, in effect, a giant bass speaker.
That can't be. The wavelength of a 20Hz signal is ~17 meters.Ideally, a speaker's diameter should be at least equal to the lowest wavelength it will handle ... at least that's my understanding
right ... let me rephrase that ... the larger the speaker diameter, the lower its low frequency distortion ...That can't be. The wavelength of a 20Hz signal is ~17 meters.
Attenuation, I think, not distortion.the lower its low frequency distortion
This is kind of a self-test for me, so I'm not googling the answer ... what I remember is that the low-frequency waveform tends to get clipped at its top and bottom if the speaker's diameter is too small.Attenuation, I think, not distortion.
Distortion would occur if the cone exceeded its linear excursion.
That would depend on how hard it's driven, no?This is kind of a self-test for me, so I'm not googling the answer ... what I remember is that the low-frequency waveform tends to get clipped at its top and bottom if the speaker's diameter is too small.
Not only that, but the neodymium magnets from today are a major improvement over the AlNiCo ones from yesterday. This helps enormously with the cone damping.That would depend on how hard it's driven, no?
That's also why small subwoofers exist today with highly pliable suspension. In the "old days", you needed a big speaker to get deep bass. Not today.
| Thread starter | Similar threads | Forum | Replies | Date |
| B | Mounting a board with very small holes (0.08 inches) to a 3D printed enclosure | PCB Layout , EDA & Simulations | 8 |
