100 inches = 254 cm
Lo_volt
Joined Apr 3, 2014
373
Reminds me of the shaker table in the environmental lab where I had a product tested. Top frequency was only about 2kHz. The base weighed about 5 tons and the top surface of the table was 4 ft square. We bolted our UUT to the table surface. Beneath the table was a magnet and coil setup similar to a large speaker. With its 3 phase 208 powered 33kW amplifier, it was, in effect, a giant bass speaker.
Reloadron
Joined Jan 15, 2015
7,932
Now that you mention it. We used shaker tables (vibration) for environmental testing and some we lowered a thermal chamber on. Vibe and thermal shock testing. Yep, a gigantic bass speaker. :)
Ron
cmartinez
Joined Jan 17, 2007
8,855
Ideally, a speaker's diameter should be at least equal to the lowest wavelength it will handle ... at least that's my understanding
18,155
That can't be. The wavelength of a 20Hz signal is ~17 meters.
Oh, you said "ideally". Maybe. I'm not sure what that means.
cmartinez
Joined Jan 17, 2007
8,855
Attenuation, I think, not distortion.
Distortion would occur if the cone exceeded its linear excursion.
This is kind of a self-test for me, so I'm not googling the answer ... what I remember is that the low-frequency waveform tends to get clipped at its top and bottom if the speaker's diameter is too small.
joeyd999
Joined Jun 6, 2011
6,456
That would depend on how hard it's driven, no?
That's also why small subwoofers exist today with highly pliable suspension. In the "old days", you needed a big speaker to get deep bass. Not today.
schmitt trigger
Joined Jul 12, 2010
2,219
If I recall correctly, from my early-70s audio enthusiast and tinkerer, the key with a speaker are both electrical and mechanical resonances. A larger loudspeaker would have a larger mass and longer throw, to avoid reaching the cone’s compliance limits.
Now, if someone knows better, let’s hear from you.
schmitt trigger
Joined Jul 12, 2010
2,219
Not only that, but the neodymium magnets from today are a major improvement over the AlNiCo ones from yesterday. This helps enormously with the cone damping.
