LF398 cap charging when hold when power mosfet commutating
Fernando_1562838485
Joined Jul 11, 2019
8
I am working on a project with a boost converter where i need a sample and hold to keep the power value for a short period of time (10 - 50 ms). I have the circuit mounted on a PCB and the S&H works fine until it starts commutate the MOSFET.
here is lf398 datasheet http://www.ti.com/lit/ds/symlink/lf198-n.pdf
my schematic
In this image u can see that S&H works fine
and if i manually modify the power with and external power resistor it also works as u will see in next image
So when my MOSFET starts to commutate while the sample period is on the S&H outputs the same than input (OK) but when is holding time the capacitator starts to charge up to Vcc voltage.
Here Blue is S&H output and red intput in detail to see what really happens. Next one is what happens when it starts to commutate
Thins that i tried:
  • mounted the same S&H circuit with all caps that says on datasheet on and external protoboard and it did the same thing.
  • make commutate the mosftet with an external function generator
  • try the same two first point with another LF398 IC
I would be very thankfull if anyone can help me and figure out what is going on with this S&H
Alec_t
Joined Sep 17, 2013
15,156
The input pin of the LF398 is very suceptible to interference.
Does your pcb have the guard ring arrangement, as per Fig 24 of the datasheet, and the recommended analogue/digital trace separations?
Is the offset-adjust pin floating?
Fernando_1562838485
Joined Jul 11, 2019
8
Thanks for your thoughs
Yes, the offset-adjust pin si floating, if i check voltatge is Vcc. I tried adding the offset circuit and does the same thing.
I don't have any guard ring but as you can see in following images logic line is pretty far from either input and Ch :
magenta is GND, red is +Vcc and blue -Vcc
I tried without the others IC connected and does the same thing.
This is my clock circuit:
green is sclock (sample logic input), magenta clock, blue V_Cs and Red V_R30
I'll try lower the high logic level down to 2.5 V as datasheet says will help
Alec_t
Joined Sep 17, 2013
15,156
You have the +15V power rail running right next to and parallel to your signal input (potencia). Any noise on the power rail could easily get coupled to the input signal line :(.
Fernando_1562838485
Joined Jul 11, 2019
8
You have the +15V power rail running next to and parallel to your signal input (potencia). Any noise on the power rail could easily get coupled to the input signal line :(.
Also, you see both intputs and outputs of S&H and input doesn't seem to have any interference i mean the input value is correct
Blue output, red input
and with constant input and more detail of what really happens
Fernando_1562838485
Joined Jul 11, 2019
8
I got it fixed, before LF398 input and output where drived into a LM393 comparador. Adding a buffer amplifier ua741 at LF398 output fixed.
I also incresead sample capacitator from 10 nF to 100 nF.
Thank you for your support though
