Level shifting signal from +5V/-5V to GND/-5V with op amp
Jorj
Joined Sep 30, 2015
19
I need to shift analog signal from +5V/-5V to GND/-5V with op amp.
It looks easy but I've tried few circuits from here and there, none of them turned out to be a success.
Can you point me in the right direction ?
OBW0549
Joined Mar 2, 2015
3,565
Make a 2:1 voltage divider from two equal resistors (e.g., 10 kΩ), with the top end connected to your ± 5V input signal and the bottom end connected to -5V (generated by a -5V voltage regulator or voltage reference). The junction of the two resistors is your GND/-5V output which you can buffer, if desired (to make its voltage independent on any output loading), using an op amp configured as a unity-gain buffer. (The op amp, of course, has to be powered by suitable supply voltages which are compatible with the input/output signal range.)
38,952
Here's the LTspice simulation of a one-transistor circuit to do the level shifting.
How close to 0V does the output need to go?
ebeowulf17
Joined Aug 12, 2014
3,307
Does this circuit scale all intermediate voltages in a linear way, or does it only work as a digital level shifter?
For example, if the input side were 0V, would you get -2.5V output?
I'm assuming you'd need a more complicated circuit to get the kind of linear response I'm asking about, but sometimes there are clever tricks I'm overlooking.
Jorj
Joined Sep 30, 2015
19
Yes the signal is analog so I can only use voltage divider or the op amp.
I'm leaning more towards op amp solution as there won't be any loss in resolution.
