level shifting signal by using positive voltage
karas
Joined Sep 8, 2011
216
Hi, i need to do voltage shifter
my input from 2.5v to 5 , i need the output to be from 0 to 2.5v , i need to do it by OP AMP and i only have 5v supply to the OP AMP , i do not have negative voltage, so can i do the circuit without using negative voltage
dl324
Joined Mar 30, 2015
18,465
Post a schematic of the circuit in question.
Is this a school assignment that requires you to use an opamp?
karas
Joined Sep 8, 2011
216
Look up differential amp connection for an op amp.
Thanks Crutschow, how can i get ride of the negative voltage of the output of OPAMP is there zero recovery diode?and can i do this circuit without using negative voltage
the circuit convert input from 2.5v to 5v to 0 to 2.5V
