Level Shifter -External Voltage (VL,VH) Controlled
dnflskfk
Joined Apr 21, 2023
7
Hi Everybody
I used a MOSFET to design a level shifter.
However, this must be adjusted according to this value by receiving an external power source.
For example, if VL = 1V and VH = 4V, the output should be between 1V and 4V
How do you design these circuits?
Thanks!
Ian0
Joined Aug 7, 2020
13,286
This design works, Ian0, but the output can not be loaded by the next stage.
No it doesn’t - see @StefanZe ‘s comments: “Where are the external VL and VH voltages?”
VL and VH are arbitrary and are the voltages of an external power supply, which may or may not be related to the 0V of the original power supply.
For completeness it needs to be stated that the said optoisolator needs its diode cathode connected to 0V and a current limiting resistor between anode and input voltage.
ScottWang
Joined Aug 23, 2012
7,505
When the A1 output is low then the R1 and R2 will be in parallel, When the A1 output is high then the R1 and R3 will be in parallel, is that right?
Even doesn't care about the in-parallel value, the Vcc voltage is not 4V, so you can't get the output voltage to be 1V and 4V, is that right?
dcbingaman
Joined Jun 30, 2021
1,065
The solution depends upon how fast it has to be. What is the expected highest frequency is has to work with or what is the fastest rise/fall times you are looking for? It also depends on what the output has to drive, that is what does it have to drive. (required source current and sink current of the output).
