Hi
I have total eight LED's and I want to turn on each LED one by one for 1 seconds only. I have connected all LED's at port D
Here is connection information, black is ground and all wires are coming from PIC ports
I wrote code that suppose to turn on each LED one by one for 1 seconds only
IDE MPLABX- 5.40
Version -XC8 2.30
Language- C
Hardware - PIC18F45K80
The problem is any LED is not turning on/off ?
Debugging code : I don't get any value at line 100
IDE MPLABX- 5.40
Version -XC8 2.30
Language- C
C:
* File: LEDs.c
* Author: Embedded System
* Created on October 15, 2020, 3:41 AM
#define _XTAL_FREQ 8000000
#include <xc.h>
// PIC18F45K80 Configuration Bit Settings
// 'C' source line config statements
// CONFIG1L
#pragma config RETEN = OFF // VREG Sleep Enable bit (Ultra low-power regulator is Disabled (Controlled by REGSLP bit))
#pragma config INTOSCSEL = HIGH // LF-INTOSC Low-power Enable bit (LF-INTOSC in High-power mode during Sleep)
#pragma config SOSCSEL = HIGH // SOSC Power Selection and mode Configuration bits (High Power SOSC circuit selected)
#pragma config XINST = OFF // Extended Instruction Set (Enabled)
// CONFIG1H
#pragma config FOSC = INTIO2 // Oscillator (Internal RC oscillator)
#pragma config PLLCFG = OFF // PLL x4 Enable bit (Disabled)
#pragma config FCMEN = OFF // Fail-Safe Clock Monitor (Disabled)
#pragma config IESO = OFF // Internal External Oscillator Switch Over Mode (Disabled)
// CONFIG2L
#pragma config PWRTEN = OFF // Power Up Timer (Disabled)
#pragma config BOREN = SBORDIS // Brown Out Detect (Enabled in hardware, SBOREN disabled)
#pragma config BORV = 3 // Brown-out Reset Voltage bits (1.8V)
#pragma config BORPWR = ZPBORMV // BORMV Power level (ZPBORMV instead of BORMV is selected)
// CONFIG2H
#pragma config WDTEN = OFF // Watchdog Timer (WDT disabled in hardware; SWDTEN bit disabled)
#pragma config WDTPS = 1048576 // Watchdog Postscaler (1:1048576)
// CONFIG3H
#pragma config CANMX = PORTB // ECAN Mux bit (ECAN TX and RX pins are located on RB2 and RB3, respectively)
#pragma config MSSPMSK = MSK7 // MSSP address masking (7 Bit address masking mode)
#pragma config MCLRE = ON // Master Clear Enable (MCLR Enabled, RE3 Disabled)
// CONFIG4L
#pragma config STVREN = ON // Stack Overflow Reset (Enabled)
#pragma config BBSIZ = BB2K // Boot Block Size (2K word Boot Block size)
// CONFIG5L
#pragma config CP0 = OFF // Code Protect 00800-01FFF (Disabled)
#pragma config CP1 = OFF // Code Protect 02000-03FFF (Disabled)
#pragma config CP2 = OFF // Code Protect 04000-05FFF (Disabled)
#pragma config CP3 = OFF // Code Protect 06000-07FFF (Disabled)
// CONFIG5H
#pragma config CPB = OFF // Code Protect Boot (Disabled)
#pragma config CPD = OFF // Data EE Read Protect (Disabled)
// CONFIG6L
#pragma config WRT0 = OFF // Table Write Protect 00800-01FFF (Disabled)
#pragma config WRT1 = OFF // Table Write Protect 02000-03FFF (Disabled)
#pragma config WRT2 = OFF // Table Write Protect 04000-05FFF (Disabled)
#pragma config WRT3 = OFF // Table Write Protect 06000-07FFF (Disabled)
// CONFIG6H
#pragma config WRTC = OFF // Config. Write Protect (Disabled)
#pragma config WRTB = OFF // Table Write Protect Boot (Disabled)
#pragma config WRTD = OFF // Data EE Write Protect (Disabled)
// CONFIG7L
#pragma config EBTR0 = OFF // Table Read Protect 00800-01FFF (Disabled)
#pragma config EBTR1 = OFF // Table Read Protect 02000-03FFF (Disabled)
#pragma config EBTR2 = OFF // Table Read Protect 04000-05FFF (Disabled)
#pragma config EBTR3 = OFF // Table Read Protect 06000-07FFF (Disabled)
// CONFIG7H
#pragma config EBTRB = OFF // Table Read Protect Boot (Disabled)
//LED STATUS
#define LEDs_PORT LATD
//#define LEDs_ON 0xff
//#define LEDs_OFF 0x00
#define TRUE 1
#define LOW 0
#include <xc.h>
void PORTs_Initialize(void)
LATA = LATB = LATC = LATD = LATE = LOW;
TRISA = 0x00; // all are output Pins, Unused
TRISB = 0x00; // all are output pins , Unused
TRISC = 0x00; // all are output, Unused
TRISD = 0x00; // All LEDs are connected to PortD. Output
TRISE = 0x00; // All are output, Unused
ANCON0 = 0; // digital port
ANCON1 = 0; // digital port
CM1CON = 0; // Comparator off
CM2CON = 0; // Comparator off
ADCON0 = 0; // A/D conversion Disabled
void main(void) //Program start from here
unsigned int count = 0;
PORTs_Initialize(); // Initialize the PORT
while(TRUE) // run forever
for (count = 0; count <8; count++)
LEDs_PORT = LEDs_PORT | 0x80 ;
LEDs_PORT = LEDs_PORT << 1;
__delay_ms(1000);
