LED with low radiation angle
dl324
Joined Mar 30, 2015
18,509
No LED will give you a beam like you'd get from a laser diode without using lenses.
If "standard LED" means through hole, use a 3mm ultra-bright with a non-diffused lens with lenses to focus the light.
DickCappels
Joined Aug 21, 2008
10,661
You might be able to find one like the LED described in the attached file.
It is green 30,000 to 60,000 millicandelas with a 15° beam. The are listed for 10¢each (US) but the minimum order is five. If found this one at my favorite distributor in Bangkok. There should be something similar at other distributors.
Other colors are available in this package -green just happens to have the highest rated light output because us humans are most sensitive around 550 nm. Not sure about cats.
I have never heard of anybody or any cat being injured by one those low powered red laser pointers.
Boggart
Joined Jan 31, 2022
82
You can get 5mm LEDs down to beam angles as low as 4 degrees. Vishay VLCS5830 is an example, rated at up to 65,000mcd at 50mA. Bear in mind that LED beam angles are the angle where intensity drops to 50% of on-axis intensity, so there is beam spill outside of that angle. You will probably still need a lens or deep reflector to tighten up the beam a bit more if you want a small dot at any reasonable distance.
Kevil
Joined Jun 28, 2020
224
It looks great with 4° only. Any advice where to buy focusing lens for it?
Boggart
Joined Jan 31, 2022
82
You can get the LED from TME in Poland, they also have a couple of small reflectors designed to fit 5mm LEDs, they may also have suitable lenses. You would have to go through their catalogue.
