Here's the deal. I've got 2 incandescent turn signals and I've added one LED turn signal per side on my project car.
With the stock flasher unit (mechanical) it hyper-flashes. With the LED disconnected, naturally it flashes normally.
I've got a solid state flasher with sound, that goes at a normal rate but none of the lights actually light up. (The flasher is unit CF13 JL-02)
I've read up on it and all I've been able to determine is either fit an anti-hyperflash flasher unit, or install a load resistor. For me this wouldn't be a problem, but I want to keep the solution as simple as possible as this is for a product I'm developing.
What's the simplest way to solve this? Would I be better off swapping the incandescents for 1156 LED bulbs?
Thanks.
Thanks.
