ok, right to the point, the closest thing i can find under 3$ that is nearly an all-in-one solution is this little black button box.
so, i'd be able to glue the bottom to my board, keep the button upwards... charge port to the side... its pretty perfect.. except..
i had to change the battery to something that could do leds for 24 hours.... i'm looking at these 35mm 650mah with little pins i could solder right on...and right now i'm testing with 16340's.. problem is, this thing charges to slow... and i just looked at it now and it actually stopped at 40mah.. it must know the other one was 47 i guess... Damn.. i guess this is out... but if anyone knows another board i could buy cheap. you would change my life. haha.
thank you.
oh and the 3 button controller photo is basically what i need (at least for modes) but... even that thing is too cumbersome and time consuming in assembly.... i need something more all in one... i'd prefer modes over rechargeable.
thank you.
