There are far more types of LED's than just the small 5mm types. Some achieve pretty high currents. It depends on the voltage supply and the LED type.it can't achieve the labeled current on the front, because of different LED Vf.
How are you determining brightness?I had to use my bench PS to sort through my green LEDs for similar brightness.
Good idea. I checked the datasheet and it puts a limit on the output current as: 5mA < Io < 500mA. I'd like to get down to 0.5mA, or at least as low as 1mA. Will I run into a limit with a simple transistor current source? Or two transistors set up as a current mirror? Are some transistors better than others for this? Maybe I should just experiment and find out. I plan to run this from a 9V or several AA's.Consider an LM317L regulator as a current source as described in the datasheet.
Is there a way to objectively assess this without expensive equipment? The 3mm blue LED's that I have are quite bright even from a side angle, but I can surely compare the light cone to one of the seemingly dimmer green LED's.A cheap LED appears to be bright when its cover focusses the light into a narrow beam.
It depends how you define brightness. If you clip the same area (cone angle) from all the LEDs you test, and you're ok with that, fine. It's kind of like shining an LED at a wall and looking at the brightness at one square centimeter in the middle of the illuminated field.Since you are concerned primarily with relative brightness an LDR in a dark case with a small hole to stick the led in seems promising.
Thread starter | Similar threads | Forum | Replies | Date |
Need help with continuity tester circuit design | General Electronics Chat | 24 | ||
S | Lavalier Microphone Tester Circuit | Test & Measurement | 5 | |
T | esc servo tester | General Electronics Chat | 1 | |
E | Why the voltage tester does not work? | Test & Measurement | 14 | |
Mil Surplus TV-7A/U Tube Tester | General Electronics Chat | 3 |
by Jake Hertz
by Jake Hertz
by Don Wilcher
by Jake Hertz
