Some people favour the "joule thief" blocking oscillator/inverter - if you don't like winding coils, you can cross-connect the parallel inductors in a common mode choke from a small SMPSU such as in a scrap set top box.With all the new LED's available with forward voltages of 3 volts or more the diode tester on a multi meter is no longer suitable for testing these components.
Can someone suggest a suitable circuit for testing these or a method.
Many thanks Rodney
Get a different multimeter. My free Harbor Freight meters work fine for LED testing. They glow dimly - probably 1mA or so.With all the new LED's available with forward voltages of 3 volts or more the diode tester on a multi meter is no longer suitable for testing these components.
| F | simple tester | Test & Measurement | 5 | |
| F | simple tester | Analog & Mixed-Signal Design | 2 | |
LED TV backlight tester - Why two DIACs ? | General Electronics Chat | 38 | |
Trying to make a moped ignition coil tester | General Electronics Chat | 43 | |
Do you believe this thing? Amazing tester ? ? ? | General Electronics Chat | 61 |
