djsfantasi
- Joined Apr 11, 2010
- 9,237
Are you aware that there is a circuit that allows for a SPDT switch to control a Kato turnout? In this case, a momentary switch is not necessary. If you use this circuit (click on the link to view), with a DPDT switch, the other set of contacts can be used for indicator lights. As no logic is involved, it is immune to noise from the switch machine and other model RR sources.
