ElectricSpidey
- Joined Dec 2, 2017
- 3,361
When using the calculator I provided it is assumed that the actual forward voltage is measured and not a guess or estimation.
Any minor variations in the supply voltage, will have little or no affect, if the voltages are measured and the correct resistor is chosen.
If a user cannot do the proper calculations and take the proper measurements, then an over the counter CC supply should be used.
And the idea that adding 3 more volts to the supply to protect from burnout is a joke, under the possible scenarios provided.
