LED matrix with sht 21 sensor and microcontroller MSP430 from Texas Instruments
Mihaela Nastase
Joined May 31, 2018
Hello all,
I want to build a led matrix, size 32 columns x 8 lines
I will built this from zero using 2835 LED(256 LEDS)
I want to display dates from the sensor SHT21(temperature and humidity sensor) with a MSP430 microcontroller from Texas Instruments.
For multiplexing I was thinking to use MOS-FET transistors.
If anyone has an idea of schematics or circuits for this matrix please help.
Thank you!
dl324
Joined Mar 30, 2015
18,454
Welcome to AAC!
How many I/O's does the microcontroller have?
With 10 I/O's, you can drive the rows and use two more to control shift registers; one for shift and one for reset.
Don't have a schematic handy. I did this to implement a scrolling display on a 5x8 matrix.
Mihaela Nastase
Joined May 31, 2018
Welcome to AAC!
I will use a uC with a minimum 40 pins for I/O(32+8). I think any idea will help me.
dl324
Joined Mar 30, 2015
18,454
Here's what I did for a 5x7 matrix:
You can replace the transistors with logic level MOSFETs. Adding another row and more columns is straightforward.
In my code, I populated a 2D array with the information I wanted to display and wrote it out a column at a time.
You need to refresh the columns at at least 100Hz to avoid flicker. Since the LEDs are multiplexed, you should drive them at a higher current than what is allowed at DC for sufficient brightness. You also need to address LED power dissipation if multiplexing stops and a column is displayed continuously.
Mihaela Nastase
Joined May 31, 2018
Thank you!
