Led Matrix Display and switching EPROM address problem
dl324
Joined Mar 30, 2015
18,524
I need a binary counter up to 256.
What IC can do this? or what circuit?
Don't know of any commercial IC's. You can cascade 2 4-bit counters.
EDIT: 74LS592. It was designed after I stopped doing design professionally. I wouldn't design it into a product because they cost $11 each in quantity 100 at Mouser.
dl324
Joined Mar 30, 2015
18,524
74LS592 is a ripple counter and I wouldn't use it. If you use it, you need to design around any glitches on the outputs.
CD4024 is a dual 7 stage counter.
Just cascade 2 CD4516.
q12x
Joined Sep 25, 2015
2,245
Here it is:
The very short version: ---video--- (watch this first)
The full version here: ---video---
Hidef of the final working circuit:
Notes:
No resistors in simulation because they will screw up the results. But put ~300R in reality on both sides of the LED Matrix, to be sure.
