I'm not against it, that's what I was planning on doing, so I can control the separate colors for a coloring mixing effect with the potentiometers.OK, so far so good. We seem to be on track as far as the controller goes. Unless you have a reason against, I'd still plan on putting the Red LEDs on one leg, Green on another, and Blue on another. If you go with transistor type current regulators (as opposed to simple resistors) you should be able to use that wall wart (12VDC@2A) you were looking at.
Honestly, while everyone was going back and forth, I got lost somewhere.I wouldn't worry too much about some of the discussion between Bernard and I about the final layout of the schematics.
I agree on this, and it will help make the wiring a little easier in the long run.One advantage of having 3 LEDs per leg is it takes the heat off the transistors nicely, which is good.
In my town, no, maybe Ft. worth, but I would have no clue where to begin looking at. The only place that I know that might have them would be Mouser Electronics.Do you have a source for low ohmage resistors? Locally I can 1-10 ohms in the standard values at ¼W.
Where do you get yours from, Bill?
