Led indicator to 240v wall light switch
Status
Not open for further replies.
ekremgusani
Joined Mar 20, 2011
157
How to add LED or Neon indicator to existing 240v wall light switch?
I want the led to lite when the switch is at OFF position and led to turn off when light switch is at ON position.
I have already installed those led indicator switches from Amazon but I would like to know to make one.
Will appreciate schematic of the circuit.
Thanks!
Dodgydave
Joined Jun 22, 2012
11,395
Put the led/neon across the light switch terminals, so that when the switch is On, the neon is shorted out Off, and will be On when the switch is turned Off.
ian field
Joined Oct 27, 2012
6,536
LED to line without isolation is a prohibited topic.
Maybe - maybe not. the only practical way is prohibited, but may be OK if not accessible. Code compliance is a whole nother can of worms.
Pretty sure there's off the shelf switch plates with indicator lights.
Status
