OKSorry I labled it wrong in the image, it is correctly wired (I did doubt myself and wired it opposite a moment ago) with the results I said.
All DMX RGB lines should read close to 12 volts when OFF.even when dmx is off its exactly the same.these are the readings
DMX H0 set to off R 0.05 G 0.50 B 0.25 All leds are on
DMX H01 Static Red R 0.11 G 0.47 B 0.22 All leds are on
DMX H02 Static Green R 0.06 G 0.46 B 0.21 All leds are on
DMX H03 Static Blue R 0.10 G 0.40 B 0.24 All leds are on
shouldnt these values change more than they are?
