LED Heartbeat
Icanmakeit67
Joined Sep 23, 2018
216
Looking for a design schematic to light 4-6 LEDs in parallel. I want to install it in a plastic heart, located inside a skeleton’s chest, part of a Halloween display. I’d like it to do a (beat-beat, short time off then (beat-beat). Repeat. If possible a way to adjust the speed.
operate at 9vdc
Thanks
dl324
Joined Mar 30, 2015
18,401
Assuming you want all of the LEDs to blink on and off together, I'd use a CD4017 with a 555 timer as the clock. Or/skip the outputs to get the on-off-on-off timing you want and vary the frequency on the timer for your needs. You'll need to have the counter outputs drive a transistor to drive the LEDs.
Alec_t
Joined Sep 17, 2013
15,126
Depending on the particular LEDs you intend to use, a series-parallel array will likely be more efficient (giving a longer battery life) than an all-parallel array.
dl324
Joined Mar 30, 2015
18,401
Schematic showing CD4017 with 2 LEDs. If you want 4 LEDs, add another MOSFET and pair of LEDs. For 6, use two strings of 3 and adjust the current limiting resistor accordingly.
18,127
I can't believe I'm saying this but I think the results would be better with a microprocessor to provide a more realistic throbbing. I've used one to throb an LED with a simple sine wave and it worked great. Hard on and off just doesn't look ... lifelike.
Icanmakeit67
Joined Sep 23, 2018
216
So the diode are general switching and the 4017 requires a clock pulse. Will an adjustment to the speed of the clock pulse say from a 555 design easily change heart beat?
dl324
Joined Mar 30, 2015
18,401
Yes. The diodes can be 1N4148 or similar. I deleted the part number so I could put them closer together and forgot to add a note. You still have to add the 555 timer I mentioned in my first post. Also add a 10k pull-down resistor on the gate and decoupling caps.
You'll have to fiddle with the clock frequency because you only have 10 outputs to implement the desired pattern.
Icanmakeit67
Joined Sep 23, 2018
216
Yes. The diodes can be 1N4148 or similar. I deleted the part number so I could put them closer together and forgot to add a note. You still have to add the 555 timer I mentioned in my first post. Also add a pull-down resistor on the gate and decoupling caps.
Not sure what you mean about the gate. Could you show an example ?
Thanks
ElectricSpidey
Joined Dec 2, 2017
3,340
Wouldn't the circuit in post #5 need an open output between D1 and D2 also D3 and D4 to produce (beat-beat, short time off then (beat-beat)?
If there aren't enough outputs to do the job, there is a way to change the timing of a 555 using the outputs of the 4017 to bring the timing circuit of a 555 to the positive rail.
dl324
Joined Mar 30, 2015
18,401
This gives a frequency of about 10Hz, so the pattern would be on 0.2s, off 0.2s, on 0.2s, off 0.4s 0.3s.
I've never had problems with NE555 driving CMOS. If you do, you can add a pull up resistor on the output of the timer or use a CMOS version.
Icanmakeit67
Joined Sep 23, 2018
216
Looks good I’ll breadboard it. I’d like more time after second beat befor the two beat sequence repeats.
beat xxx beat xxxxxxxx beat xxx beat.
I’ll try this first. Doesn’t the 4017 need power at pin 16 and ground at pin 8?
dl324
Joined Mar 30, 2015
18,401
You can play around with the number of counts that the LEDs are on and the frequency. Personally, I think I'd like the heartbeat to be slower.
Yes. My schematic editor doesn't show explicit power connections for most parts - and I like it that way. I don't like the clutter power connections or decoupling caps. Anyone who knows anything will know that you need to connect power and supply appropriate supply decoupling.
