LED Heartbeat
Icanmakeit67
Joined Sep 23, 2018
216
Looking for a design schematic to light 4-6 LEDs in parallel. I want to install it in a plastic heart, located inside a skeleton’s chest, part of a Halloween display. I’d like it to do a (beat-beat, short time off then (beat-beat). Repeat. If possible a way to adjust the speed.
operate at 9vdc
I need a viable circuit. Have breadboarded what has been suggested but nothing works. Simple flashing but no gap between beat beat? I want beat xx beat xxxxx beat xx beat repeat
djsfantasi
Joined Apr 11, 2010
9,237
Your clock (either with a 555 or the Schmidt trigger gates) is running too fast. Adjust it so it runs slower with the pot.
Do you code? Much better control can be had with a microcontroller.
eetech00
Joined Jun 8, 2013
4,724
Try the circuit I just posted #21. VR1 varies the speed between 50BPM and 100BPM.
The LEDs should flash to mimic the double pumping of a heartbeat. If the gap isn't wide enough, we can adjust.
wayneh
Joined Sep 9, 2010
18,164
I breadboarded this it doesn’t work?
If we had a nickel for every time we heard that...
The solution is always the same - divide and conquer.
First make sure the timer is running. Use an LED to test. The timer should be running slowly enough that you should be able to see it flicker. If you have a multimeter, check voltage at the power pins.
Likewise check that the counter counts. You can manually apply a "clock" signal to see if the count advances. Again, you can use LEDs to to test the output. You'll usually see it skip ahead on a manual clock because it bounces but that's OK.
You can also check the output section (the transistor) by bypassing the counter and applying a manual signal.
Icanmakeit67
Joined Sep 23, 2018
216
Yeah everything is working. I have a premade 555 clock bench module that’s adjustable with output power and clock signal connections. It also has a switch to an onboard LED to check operation and speed then switch to output connections to use in test circuits. It’s working fine. 4017 is also working fine as part of 10 led chaser. I moved it to another breadboard to build any ideas to try.
AnalogKid
Joined Aug 1, 2013
12,268
A few years ago I built an audio heartbeat simulator to help a new puppy sleep at night. Here is that circuit re-worked for your application. It looks like a lot of parts, but it actually has fewer components and connections than previous circuits.
U1A-R1-C1 form the basic oscillator. D1 and R4 shorten the positive half-cycle for the closely-spaced double flash. R2-C2 and R3-C3 are differentiators; these set the on time for the LEDs. If you want the second flash to be slightly less bright to more accurately simulate the diminished second thump in a heartbeat, reduce R3. The shorter flash sill be seen as dimmer.
The heart of the circuit is U1C. This acts as an inverted-input OR gate, the DeMorgan equivalent of a standard NAND gate. If either input goes low, the output goes high and turns on the LEDs through Q1.
http://hyperphysics.phy-astr.gsu.edu/hbase/Electronic/DeMorgan.html
I prototyped this circuit, and these values give a decent approximation of a heartbeat. None of the part values are critical, and can be scaled to work with parts you already have. For example, increasing R2 and R3 to 1.0M and decreasing C2 and C3 to 0.047 uF will give the same results. Decreasing R2 and R3 to 330K and increasing C2 and C3 to 0.15 uF will have similar results.
C4 is the power supply decoupling capacitor for U1. It should be located as close as possible to the IC power and GND pins.
Overall, the circuit has four R-C timers. Two of them form the squarewave oscillator with a non-50/50 duty cycle, and two form the two flashes. All four can be made adjustable by replacing the fixed resistor with a smaller fixed resistor in series with a trimpot. For example, R1 has the major effect on the circuit's heart rate. Decreasing R1 to 750K and adding a 500K pot in series gives a reasonable adjustment range. This adjustment will affect both the overall frequency and the time delay between the two flashes. To make that time delay independent of the frequency, add a diode in series with R1 as in eetech's schematic #20.
ak
AnalogKid
Joined Aug 1, 2013
12,268
Here's one way using CD4017B.
Generates about 50-100 beats per minute.
LEDs 20mA@2v each.
Uses 9v supply.
Is it just me, or is there no reason for R2, D2, or U1B? Other than basic frequency, the clock signal duty cycle and phase have no effect on the output pulses of a 4017. The output pulse widths are set by the input frequency only; narrow or wide clock pulses do not appear at the outputs. The oscillator period sets the on-time of a single flash, and the number of outputs skipped over sets the time delay between flashes. U1 and all of its components can be replaced with a 555, 1 R, 1 C, and 1 pot.
ak
eetech00
Joined Jun 8, 2013
4,724
U1B initially clocks U2 on positive edge, without U1B, U2 would clock at power on.
Its been a while, so I don't remember if that matters, other than changing the initial delay.
It seems what I've shown, in effect, is really only changing frequency.
I tested this on bench with a pulse generator. I'd have to test with CD4093B.
ak
Yes. The oscillator could be replaced with 555.
eetech00
Joined Jun 8, 2013
4,724
ak
Simple circuit...but...if the supply voltage changes, then all the RC timings change.
Icanmakeit67
Joined Sep 23, 2018
216
I’ll wait to breadboard. I have the components but let me know the verdict please
