LED Driver
RodneyB
Joined Apr 28, 2012
698
I am trying to learn how to work out what LED driver to use and how to connect the LED's
I want to connect 50 LED's for example to a 12 Volt supply. The LED's have the following specifications
Vf = 2.2V
Vi = 25mA
In the past I would have used the LED calculator found at http://led.linear1.org/led.wiz
Using the above details This calcuator shows 5 LED's in Series with a 47 Ohm resistor and 10 of these arrays in Series.
I would like to be able to calculate this myself and in turn use a driver which from what I read is more suitable method.
Any assistance will be apprecieated.
MikeML
5,444
If driving 25mA LEDs, the parallel strings of 5 LEDs in series with resistors is the best way to go.
To use a proper constant-current driver made expressly for LEDs, you would have to look connecting all 50 LEDs in series, and then finding/building a driver with an open-circuit voltage greater than 1.1* 50*2.2V >= 121V.
If you split the strings in two strings, you would need two drivers, each with an open circuit voltage greater than 60V.
ScottWang
Joined Aug 23, 2012
7,501
considering the LED life and brightness, you just using 80% of 25mA, that is equal to 20mA, and the limiting resistor is 56Ω.
