looking for Led driver ic solution to power led lamp with 170 leds (5mm led 2.2v 20ma) 170 -80 no.
V Thread Starter vinit1277 Joined Mar 8, 2013 1 Jul 23, 2018 #1 looking for Led driver ic solution to power led lamp with 170 leds (5mm led 2.2v 20ma) 170 -80 no.
S sghioto Joined Dec 31, 2017 8,749 Jul 26, 2018 #2 If you wire the the LEDs in a series-parallel configuration you can power the lamp with a 12 volt 2 amp power supply. SG
