LED Dimming
Robson Jhon
Joined Apr 1, 2018
Hey I was searching solution for my query and I found somthing similar here , I have 0-10v DAC (interface with pycom) and giving analog output (converted from digital input) to RECOM constant current LED light driver (RACD-150A) but I need to know how 0-10v Signals will communicate with LED light driver to control the brightness of light ?
your intel will be appreciated
danadak
Joined Mar 10, 2018
4,057
I can only find datasheet but seems a direct connection from DAC to RACD-150A
will work, as datasheet confirms it can use an analog Voltage of 1-10V to control
current in LED.
I would advise that you get the actual user manual to confirm this.
Regards, Dana.
