Where was that mentioned?First, given that you’re using the OSRAM LEDs mentioned earlier
What LEDs are you using exactly?the LEDs are rated for 1 amp,
We still don't know what LEDs the OP is using.First, given that you’re using the OSRAM LEDs mentioned earlier,
Sorry. I thought your example WAS the LEDs the TS was using.We still don't know what LEDs the OP is using.
He gave a voltage spread of 3.6-3.7V for the forward voltage and I was providing datasheet examples that showed that that wasn't realistic unless he had ones that had forward voltage matching.
Then he said he had LEDs that had been binned for forward voltage, wavelength, and brightness. Which is also unlikely. Binning by brightness is free. Binning by forward voltage would cost more and I've never heard of binning by wavelength. Of course, I hadn't heard about forward voltage binning until a decade ago or so. Maybe that came with the advent of so many inexpensive LED flashlights using LEDs in parallel with no ballast resistors.
i'm using high power LEDs rated for 1 amp.If you don't care about variations in brightness, why are you using a driver chip in the first place?
What is it that you are doing with these LEDs? How much can your supply voltage vary by?
Your solution may be nothing more than a series resistor in series with one or two LEDs to make up a string and then enough of those strings in parallel to get the total light output you need.
What do you base that expectation on?Connect the LEDs as you have them wired directly to your 12 volt power supply and see what the current reads?
Could you PLEASE give us a part number for the LEDs you are using?i'm using high power LEDs rated for 1 amp.
these are used on vehicles with 12 volt battery systems and various charging systems.
supply voltage can vary from 11 to 15 volts. that's why i can't use resistors.
I deleted that comment. They should pull 1 amp total but they won't fail if rated 1 amp at 12 volts.Why would you expect LEDs rated for one ampere to only pull just over half that when connected like this?
Where did he say that they are rated to pull 1 A at 12 V?I deleted that comment. They should pull 1 amp total but why would they fail if rated 1 amp at 12 volts?
Being next to each other on the same reel does not necessarily mean that they are from the same die or even the same lot of wafers -- but it is pretty likely.all 4 LEDs are very close to same forward voltage.
they're the same part coming on same reel.
forward voltage is 3.6 to 3.7 volts.
is this close enough that i don't need the resistor?
i don't know how to indicate matched LEDs.
bottom line is - if LEDs are matched and driver chip is producing 1 amp, does each string get 0.5 amp?
thanks
Happens to all of us.I stand corrected. Misread the post.
Why not? I have some LED bulbs in 194 form factor. They don't draw an amp, but they have a resistor on them.these are used on vehicles with 12 volt battery systems and various charging systems.
i understood the driver chip limits or sets the current regardless of forward voltage.What do you base that expectation on?
I would expect at least two, if not three, failed LEDs in short order.
Note that the post I was responding to was specifically talking about just the four LEDs connected as shown directly across a 12 V battery, so no driver chip at all.i understood the driver chip limits or sets the current regardless of forward voltage.
