Bordodynov
- Joined May 20, 2015
- 3,431
You can check it yourself. If of course you have my model library.
Hola, I do not intend to derail this thread but I would like to know how do you actually intend to use this once you get it working.I need to pulse a LED at 200ps. Using the below circuit, i can pulse led at ns intervals. Can anyone help me to tune the RC components in the collector terminal of transistor to get 200ps pulse.
Thanks in advance
First - let me qualify my knowledge and experience on this - I have none. So I'm wondering what would happen if you reversed the LED and let the inductance kickback from the coil fire the LED? What kind of voltage would be seen there? And that would answer what resistance would be needed to protect the LED - IF the resistor is required at all.hi meena,
This is using a generic NPN and LED
Stepping the Ctune.
Shows the LED current and Voltage.
E
