Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
i have no datasheet at all for the LED lights, all i have is its length.
long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
as soon as i fix the chandelier to the ceiling and bury the driver inside the hub, it works for 1 hour then the driver burns, and trips the breaker.
the seller suggested its just overloaded and to split the 24 arms in 12 arms each for its own driver, and i did that, worked fine on the ground for 3 - 6 hours continuesly "well ventilated", as soon as i hanged it to ceiling again, worked for 2 hours then again, driver burnt, breaker tripped.
im almost sure going back and forth with chatgpt, copilot & gemini, is its a driver issue, and basically its just not well ventialted, but i have no option to ventilate it.
if this driver is wrong for this chandelier type, which would be the correct one
please check all pictures attached for the external and internal driver components.
