Hi folks
Electronics is not my forté (as in, I have zero experience with it) so bear with me if my model sounds lousy or my language is not accurate.
Anyway, I’d like some advice on the following please. I need to design a circuit which achieves the following:
1. Receive 5v incoming at 500hz from a flow sensor
2. Output that to around 3hz for a warning LED to flash at a decent frequency
3. The 500hz (or 3hz) signals should also close a relay which activates a pump
4. However, when the incoming signal switches to constant 5v, the LED should stop flashing (Constantly on) and the relay should open, stopping the pump
So far I’ve been doing the following:
1. A 555 timer configured as frequency divider drops the incoming 500hz frequency to around the desired 3hz
2. A second 555 in monostable mode receives that 3hz signal (which has very high duty cycle and therefore makes an LED on the output appear constantly lit) and outputs a 3hz signal with lower duty cycle - thus an LED will flash at a human-readable rate
3. When the source goes from 500hz to constant 5v, the LED turns solid.
4. A third 555, also monostable, fed by the output of the second 555, takes that 3hz signal and increases the duty cycle significantly, outputting that to a relay which is held open by that 5v output. Note: I don’t want to use a pulse relay because it’s important that the pump stop if signal is lost for whatever reason.
This model I’ve made works (lights flash and relays open accordingly) but every now and then the pulse from the third 555 to the relay ends (no matter how long the output is, it’s always a pulse) and the relay opens for a split second, before closing again with the next pulse.
So my questions are as follows:
1. is this a sensible design or are there more elegant ways to achieve the desired result?
2. Should I be using other components instead of 3 x 555s?
3. How do I prevent the output from the third 555 from opening the relay occasionally while there’s still a pulse being fed into the system?
I hope this explanation makes sense!
Edge
Edge
