I recently finished constructing and programming a 7x7x7 Blue LED Cube, so I thought I'd share a brief overview of the Cube itself. Please ask any questions if you are interested in making a cube, hopefully I can help you out.
Parts List:
343x Blue LEDs
49x 470 Ohm Resistors
7x 2N2222AG Transistors
Approximately 30m of 0.9mm galvanised steel wire
1x Arduino Mega 2560
Equipment Used:
Soldering Iron
Heatsink
Pliers
Multimeter
Vice
Software Used:
Arduino Development Platform
Processing (Used to design the frames & effects)
The cube is able to process 142 frames per second, that is, 1 frame every 7 milliseconds. Within this time period, it loops through a still frame 7 times (Each cycle of POV lasts 144 microseconds). This is able to compensate for flickering during video recording, allowing all cameras to record fluid video without distortion.
The cube itself is controlled with an Arduino Mega 2560. For each frame in memory, the Arduino reads and bit shifts 49 bytes of data for an encoded duration. This allows for the cube to be applied to a variety of purposes, from text display to effects to music visualization.
https://www.youtube.com/watch?v=CKCjsbNEUUE
The frames were generated through complex Processing scripts, allowing for a multitude of operations such as shifting in any direction (seen in the rain effect), and an edge shift (seen in the scrolling text around the outside of the cube). These scripts were used to perform the basis of calculations for fireworks, as well as sine waves in 1, 2 & 3 dimensions (seen in the video).
In this cube the supporting structure was made 0.9 mm galvanized steel wire, straightened by stretching the wire. The 5mm Blue LEDs are positioned 30mm apart, with the anodes being attached to the verticals (white wires in the image above) & the cathodes are attached to the horizontal layers (green wires in the image above bottom right shown passing through NPN transistors). The Arduino Mega 2560 R3 is positioned on a suspended platform, with the anodes controlled on the Digital Pins as opposed to the cathodes on remapped Analog Inputs.
As the cube is divided into layers (shown in the schematics) I made a template with drill pressed holes that I could fit the 49 LED's in with a spacing of 30mm while soldering the layer. By using a template, the LED's were aligned consistently. On the wooden template, I attached several lugs that allowed me to position the structural layers consistently and accurately. Soldering the layers took me approximately 6 hours, as all of the LED's legs need to be bent to attach to the structure.
I then made a jig out of foam that allowed me to join the first two layers. Layers are joined by soldering vertical straight pieces of galvanised wire to the anodes of the LED's. Once I had done two layers, I shifted the jig up a layer, and mounted the next layer until I had joined all seven layers.
The vertical wires (49 of them) attach to the Arduino on Digital Pins 0-48 directly, shown in the above schematic. At this stage, you essentially have a 2D display with 49 pixels.
To add the third dimension, a small circuit is required (shown below), which uses seven transistors (one for each layer) to connect the cathodes to ground in sequence, so a 1 pixel resolution is the result. This could be done through an IC, however I opted for a small prototyping board, which has seven transistors (I used 2N2222AG - High Speed). The emitters of these transistors are wired to a common ground on the Arduino Mega 2560, each collector is connected to one of the layers, and then the base's are connected to the Arduino's Analog Pins A0-A6.
Please feel free to ask any question, I more than happy to help!
Hutchie
If we want to store hex data then what to do??In the original prototype shown in the video I just have a large array of binary representative data, however I am now working on loading the frames live over serial. I choose to avoid file storage on the arduino.
| Thread starter | Similar threads | Forum | Replies | Date |
5V charging cube: says PPS & PD 3.1 Certified | General Electronics Chat | 5 |
| Similar threads |
