ebeowulf17
- Joined Aug 12, 2014
- 3,307
I ran out of time to draw it up yesterday, but I think I have a plan that accomplishes the same thing as the circuits above, using a regular single pole switch, two MOSFETs, and two resistors in place of each double-pole switch.Thanks Guys
This is awesome!!! Works perfectly. I am able to get my reading for my resistance and a visual aid too.
Thanks Ebeowulf17 and Narkelptk for the help. Much appreciatedNow I wonder if I can use a transistor
I will look into that do some reading up on it
It's possible that the intrinsic body diodes within MOSFETs will allow leakage current which affects the resistance readings. If so, the polarity of the meter probes would matter when measuring resistance.
I don't think it could be done well with bipolar junction transistors (bjts) instead of MOSFETs because the voltage drops (Vce) would alter all the meter readings.
I can't promise anything, but I might have time to draw it up this afternoon on the train ride home.
