"leak voltage" from mosfets when no load.
Toebs
Joined Oct 9, 2014
55
Hi!
So I am preparing to get some prototype PCBs made from my schematic. I have been testing on bread board and seems to work, I have however a few questions before laying out the board and sending gerber files to production.
I have 4 mosfets (Q100, Q101, Q102, Q103) on the board to switch 12V DC from pins on my uC (electric imp). However If i measure on the output from mosfets (i.e. P100), when the i/o pin is low, I read like 5-6V even thou I would expect to see 0V.
If i put a load on, even small like 10kOhm, i will read 0V as expected.
Given that I will all ways have a load on, it is not really a problem, but I was just wondering why this is happening?
Another thing: look at the block "12V control for electric lock". Is the CARD_PIND sufficiently protected and does D201 and R202 make sense?
And last: if you see anything else that seems off please comment :)=
Alec_t
Joined Sep 17, 2013
15,119
Result of diode leakage current flowing through your meter?
IMO R202 would offer more protection if it were between R201 and the zener.
BTW, if this lock is a car door lock the mods may close this thread as being against the Terms of Service.
Alec_t
Joined Sep 17, 2013
15,119
The diode leakage would give a higher voltage reading if you used a higher-resistance meter. But even a cheap DMM might have a higher resistance than the typical 1 megohm resistance of a scope.
Toebs
Joined Oct 9, 2014
55
That will do the job.
Ok updated the schematic with discussed changes. Does the transistor inverter look to be configured right?
I only get 2V on the lock status pin (CARD_PIN1), its enough to be seen as digital high, however why is this I only get 2v?
18,108
That's what I was thinking, but he data sheet for the diode specifies a max of 25nA at 20V (and more at higher temp). If the TS's meter is 10MΩ and he's seeing 6V, that's 600nA. Curious.
Toebs
Joined Oct 9, 2014
55
Config looks ok.
What 'low' voltage do you get at Q200 drain?
When gate voltage is low i measure:
2V without load between drain and ground on Q200 and 9.8V with load (80mm PC fan).
The meter im using is a TENMA 72-7770 rated at 10M ohm input impedance. Later today I will try with high quality meter instead
Toebs
Joined Oct 9, 2014
55
?? The load should be between drain and 12V.
What drain voltage do you get when Q200 is turned on?
Yeah sorry, poorly written by me, what i meant to say was:
Measuring from drain to ground:
Results with load connected (between 12V and drain, as in schematic):
Q200 ON: 0V
Q200 Off: 9.83V
Results with no load:
Q200 ON: 0V
Q200 Off: 2V
Measuring between drain and 12V rail:
Q200 ON: 12V
Q200 Off: 2.1V
Q200 ON: 12V
Q200 Off: 10V
Alec_t
Joined Sep 17, 2013
15,119
So, if with no load there's 2V across a 10meg meter, the diode+circuit-board leakage current is 200nA. Seems reasonable.
Toebs
Joined Oct 9, 2014
55
I just put a 33kOhm resistor in parallel with D200 and measured without load. I still measure like 9V across D200 (which would be parallel with the load if there was any).
Does it still seem reasonable?
Alec_t
Joined Sep 17, 2013
15,119
You said 2V. Why now 9V? The load shouldn't connect in parallel with D200; it should go in series with D200.
18,108
Something still makes no sense and is probably a measurement artifact we aren't aware of.
Q200 ON: 0V
Q200 Off: 9.83V
The on resistance of Q200 is in the mΩ range, so there should be a tiny voltage across it when ON. Maybe not enough to see on the 20V scale of the meter.
Q200 ON: 0V
Q200 Off: 2V
Perplexing unless there is sufficient diode leakage.
Q200 ON: 12V
Q200 Off: 2.1V
This is a puzzle, since you are showing a 9.9V drop across the load with no current flowing through the load. You would expect rail voltage on the low side of the load, if no current is flowing because Q200 is OFF.
Q200 ON: 12V
Q200 Off: 10V
If all the current is coming through the diode, you have 10V driving a 10MΩ impedance, or 1µA. That's out of spec for the diode.
Toebs
Joined Oct 9, 2014
55
Hi guys, thanks for the patience :)
Oh wait a minute: There's a direct path from the drain to 3V3 through R201!
Oh shit yeah, true. Im not really sure how to fix this. I was thinking about putting a diode between Q200 drain and button "1" but then I cannot detect on the CARD_PIN1 if mosfet was opened by uC. Any suggestions?
Also I just realised I do not need the whole transistor logic inverter circuit (R203, R204 and Q201), since I do not need to use the interrupt to wake up anyways :)
