Hi all.
Yesterday I received this meter of electronic components. I began to study his work. Everything seemed to be fine and expected, even better than I thought.
But there is no large experience of measurements directly in circuit. Therefore, I decided to ask a question on the forum.
In measurements in circuit, you can use a voltage of 0.5 volts or only 0.2 volts?
Indeed, as is known, the accuracy of the measurement depends on the magnitude of the voltage.
