LCD display low level programing
Samantha Groves
Joined Nov 25, 2023
162
Im looking for a LCD display which is programed bitwise for example a 256x256 display will have 9 bits for x position and 9 bits for y position as well as power and any serial communication pins so 20-25 pins.Thanks!Also to be available in EU
Ian0
Joined Aug 7, 2020
13,278
What exactly do you mean by "bitwise" I'm guessing that you want to set the colour/brightness of a single pixel at a time? Are you looking for RGB displays or monochrome?
Samantha Groves
Joined Nov 25, 2023
162
RGB and your guess is correct.Thanks for helping me out and investing in time.
Samantha Groves
Joined Nov 25, 2023
162
BobTPH
Joined Jun 5, 2013
11,647
You are unlikely to find an LCD with a single bit interface because it would be far too slow. However, you can create your own single bit interface in software built upon the existing hardware interface.
35,178
Is there anything better?For example Im very good at working with a 4 wire resistive touchscreen without microcontroller where you read the position as a analog voltage signal so I guess is there a grid of leds honestly?
Optical sensing is out of date. They now use high resolution sensing with resistive, capacitive, acoustic wave sensing.
