Layer missing on PCB??
30,661
I am trying to get a boards made by a Popular Chinese PCB site.
I sent Kicad originated Gerber files but they keep coming back and saying
'"Your file is missing two layer resistance welding".
I have no idea what they are asking for?
Anyone enlighten me.
jpanhalt
Joined Jan 18, 2008
11,087
http://www.we-online.com/web/en/ind...1/englisch_2/Designguide_WIRELAID_0813_EN.pdf
http://www.tech-etch.com/flex/flex_design_guide.pdf
Neither seems to answer your question, but they may give a clue as to what that error means.
The first link includes an additional modifier, braid. I suspect if one were using braids, he would know. There is a separate Gerber layer for that.
So, my guess is that the description about welding in the second link is closer to the problem. Do you have blind vias connected to some but not all layers above them?
It will be interesting to hear of your experience. My experience with iTead(iMill) was mostly positive. It took about 1-1/2 weeks longer than Oshpark, but they also shipped many more boards than I ordered -- I was expecting 3 and got 10 or 11. Dimensions were accurate. The main negative was no bottom silk screen.
John
30,661
Thanks, I think I have it sorted (hopefully) now, The reason for the confusion is the on-line Kicad manual for plotting suggested Gerber files does not exactly jive with the version I am using, so the couple of files that were missing were the top and bottom solder, not sure why they refer to them as resistance welding layers?
30,661
Just an ordinary 2 sided board, nothing fancy, we got it sorted, but evidently '"Your file is missing two layer resistance welding" means top and bottom solder layer, it would have been fairly plain at the beginning had they said this off the bat.
I have no idea where the term resistance welding in reference to a circuit board manuf comes in?
