Lava Lamp
NoneOfTheAbove
Joined Oct 18, 2022
24
Hello.
I am a beginner with electronic stuff, but I did buy a Lava lamp not so long ago, which had led lights that change colors. However, I did not like that it changed colors so fast (about 2 seconds per color) and I would like to have it change much slower. I opened up the lamp to look at the circuit board but have gotten stuck and have no idea how it could be done.
Anyone that can help?
LesJones
Joined Jan 8, 2017
4,536
I would guess that the 8 pin DIL device is a microcontroller. Telling us it's part number would be a great help. (In your pictures any part numbers on it are hidden by the white wire.) If it is a microcontroller you would probably need to modify the code in it to increase the time delays. Tracing out the schematic of the board would also be helpful.
Les.
NoneOfTheAbove
Joined Oct 18, 2022
24
Les.
Hi, thank you for your reply.
It says 262A right above the chip.
And I don't have the schematic of this circuit :/
NoneOfTheAbove
Joined Oct 18, 2022
24
Les.
Or which number is relevant? Maybe I picked the wrong one.
LesJones
Joined Jan 8, 2017
4,536
I do not recognise 262A as a common microcontroller. It could be an in house part number. If that is the case you are unlikely to find any data on it. I did not expect you to be supplied with a schematic. It looks a fairly simple board so tracing out the schematic should not take very long. If the 8 pin chip is not a common microcontroller then I think you have no chance of changing the timing.
Les.
hexreader
Joined Apr 16, 2011
619
I guess I have to remove it to see the number underneath? Cause there's nothign written on the top side of it.
No - no - no
Do not do that....
Unlikely that there will be anything written underneath.
We do not need to know what chip is fitted now, only what will be compatible with the pin-out
It is just possible that an 8-pin PIC12 might do the job if pin 4 (MCLR) were to be cut off, but most PICs require that MCLR is connected.
NoneOfTheAbove
Joined Oct 18, 2022
24
No - no - no
Do not do that....
Right now I don't understand much of your message, but in case it is not visible, there are 2 pins that are not soldered to the circuit board
MaxHeadRoom
Joined Jul 18, 2013
30,776
If you have the time and patience, it should not be difficult to reverse-engineer the board, it may make it somewhat clearer if the IC is a micro.
As mentioned, it could be a trivial program for a small Microchip processor.
Only a one sided PCT board.
NoneOfTheAbove
Joined Oct 18, 2022
24
At this point it is starting to sound really complicated for a dude like me.. almost like I want to find someone to do it for me now :I
Reloadron
Joined Jan 15, 2015
7,922
I count 9 LEDs labeled R,G,B three each so my guess id the three colors are Red, Green, Blue. I count three transistors so likely the three transistors are driving three LEDs each. Best guess is I agree the chip an 8 pin DIP chip is likely a uC (micro-controller) coded to digital out three channels driving the three transistors with a delay of 2 seconds for each channel. Less seeing the actual schematic it's hard to guess exactly what that "ball game" chip actually is. Yep, less any part number on the top of the chip it's pure speculation. :(
Ron
