Latching Applications
demartinoj
Joined Jan 25, 2009
10
I am trying to energize a circuit with some sort of latch component. My original thought was to use a mechanical latching relay. After some thought I have decided I would like to use a solid state device for the latch instead. I was considering using a JK flip flop and toggle the Q and Q not with the set and reset. I am not sure that this is a proper application for the JK flip flop. Does anyone have any suggestions on other solid state devices that could be used for latching similar to a latching relay or have an opinion on the use of the JK flip flop for this application? All my circuit logic is 5Vdc.
masa6614
Joined Nov 9, 2008
48
albertos circuit is good, or you can try these as well,
one of these guys ( http://www.allaboutcircuits.com/vol_3/chpt_2/11.html ) or transistors to accomplish it like they had in the daigram, cus Vcc is 5V make sure to use logic level fets, and there will be a bit of a voltage drop across top pchannel to the load.
Or you can use a j/k like you wanted, ( http://www.fairchildsemi.com/ds/74/74VHC112.pdf ) looking at the truth table, it dont matter what J, K, Q', or the clk is, if you just ground the Clr, and toggle the PR, Q will change which you set up to energize on/off the circuit you wanted
