Laser modules failing...
Externet
Joined Nov 29, 2005
2,631
Hi.
5mW green dot laser modules not surviving 5 minutes on.
Even 'industrial' lasers are meant for 45 seconds on - 15 seconds off, as in
----> https://www.ebay.com/itm/3pcs-INDUS...559507&hash=item33e8b8acf7:g:hpoAAOSw--Fa4UBI
I do not need more than 5mW optical, but 12 hour on, 12 hour off for at least 1 year, in that small package. Suggestions ?
And: its control electronics is supposed to limit current/power and compensate for batteries getting lower; so what is the real expectation for power supply ? Does it have to be 3.000 V or can 4.2 to 2.4V make them work reliably ?
BobTPH
Joined Jun 5, 2013
11,515
Sorry, I didn’t look at the link. Yes, that probably is a constant current driver, which means changing the input voltage woll have no effect.
Bob
Externet
Joined Nov 29, 2005
2,631
Thanks.
Yes. but Chinese lie too much. Having spring contacts, the 'industrial' ones on link look more like for pointer/pen; for 2x AAA. Which would be under 3.0 V after a minute, and thus then, stop working. So that is obviously a misleading 'spec' invented by sales people.
Infrared laser diodes for DPSSL are supposed to work down to Vf around 1.8-2.2V = spent 2xAA cells...
mcgyvr
Joined Oct 15, 2009
5,394
Thanks.
Good luck with your assumptions and stereotyping..
Maybe intended for a 3.6V lithium battery...
What supply voltage were you using?
olphart
Joined Sep 22, 2012
125
I'm on Externet's side: Asian spec sheets are rife with errors.
The most common I see is using peak current / short duration retold as constant current.
An occasional oversight is one thing, this is pervasive fraud.
mcgyvr
Joined Oct 15, 2009
5,394
Don't take my responses as falling on or taking the "Asian" side..
If you don't know by now that when you purchase that stuff that all bets are off then I really feel bad for you..
"fool me once, fool me twice" saying..
Bordodynov
Joined May 20, 2015
3,431
There are two types of green laser modules. Using an infrared laser and a nonlinear optical converter. Such modules can work from 2.5 volts. But there are modules with a true green laser. The operating voltage of such lasers can reach 8 Volts. The Chinese solved this problem using a stabilizer on a charge pump. But the minimum supply voltage is 3 Volts. I solved this problem using a DC / DC boost converter with an output voltage of 5 volts. But maybe 3.3 volts too. The fee for this turned out to be quite small.
