Large Diode Pass Overvoltage?
Status
Not open for further replies.
russwr
Joined Aug 29, 2017
132
Can a large amperage stud diode as standard type low frequency, on series MILLIAMPS current, pass properly a much way higher over voltage in reverse direction , reverse bias, repeatedly as high frequency source, and not fail over time? I thought only overheating by large current failed diodes. The ZENER diodes pass current in reverse. A new energy system described power supply uses 70HF160 diode, 1600v 70A, that removes electrons during over voltage pulses.
The final degenerated , more unstable Hydrogen + positive Oxygen fuel ions , from Voltrolysis, and laser excitation, then fire with spark, forming huge energy release, with Patented name - Thermo Explosive Energy. The new Meyer cell circuitry. Excerpts on You tube, and company Manuals, Patents, etc. , from The earlier Water Fuel Cell in Ohio. This technology may replace the oil to fuel.
Give us or link us to a diagram and/or schematic of this energy system described power supply so we can make a intelligent assessment of your question.
28,286
In addition to the request in post #2, I am requesting an actual explanation of just what you are actually asking that high power rectifier to do. Presently I do not understand the requirements, so I am unable to provide correct advice for this really very interesting project.
russwr
Joined Aug 29, 2017
132
The heavy rectifier is asked to pass milliamps current forward just temporarily,within it's rated voltage, (pulsing circuit) then over voltage in reverse direction , removing electrons from a charged cell in the forward area. I wanted to know, since this is similar to a Zener diode application in reverse flow, that the large mass of rectifier would NOT burn out from this consistent high over voltage, since there is no heavy amps flow at all.
Water cell delivers charged molecular ions ONLY from Voltrolysis, foam tiny bubbles mass rising upwards, (thousands of volts) but need the outer orbital electrons removed, so at a further unstable, higher, energy level , just before firing. - Meyer Patents to run autos, industry, home heating, and blast furnaces. Separate Patent - Electron Extraction.
The chief electronics engineer Chambers fled to Canada after Stan Meyer was poisoned. I suspect after signing tech agreement that all designs belong to the company he came up with, but then reneged, and left Water Fuel Cell Company. Patents time ran out, now in public domain. Others, for some time now, are doing bench duplications. See You tube videos and Internet data.
Free energy crap.
28,286
The fact is that excess reverse VOLTAGE will usually damage a diode if it is enough to cause electrons to migrate back over the barrier. That sort of destruction does not cause much heating as it does the damage.
AND NOW MY QUESTION: Why are you telling me about some magical water cell producing tiny magical bubbles with massive amounts of energy??? I do not have the funds available to support such a project, and my commercial engineering charges are rather high, because of the learning I wold need to do for the project.
As for high current diodes and excessive revers voltage damage, what I can let you know is that reverse voltage breakdown damage is quite different and separate from damage produced by forward current.
LowQCab
Joined Nov 6, 2012
5,102
Stanley Myers stuff supposedly uses specific resonant-frequencies that facilitate
the separation of the Water-Molecules.
He was supposedly murdered for it, so there might be something useful lurking there.
It's certainly not the first time something like this has been perpetrated by the Clowns-In-America.
Who needs oil, fission, and fusion when we can run the world just by breaking up way molecules and then putting them back together? No pollution, no running out of resources, just infinite free energy!
It's a shame that otherwise good people get hoodwinked into these lies by con-artists. Eventually most figure out they've been suckered and treated like fools.
To the OP, it's a pipe-dream created by people wanting to vacuum money from your pockets.
russwr
Joined Aug 29, 2017
132
The situation was using the large rectifier in short very low duty cycle pulses with excess high voltage, , not large on time percentage.
The only thing murdered was simple HS physics.
Wendy
Joined Mar 24, 2008
23,820
I'm locking this thread because there isn't any such thing as free energy (AKA overunity) which is not allowed on ACC.. read the Terms and rules and User Agreement. Mayer was a scam artist of the first order and no scientist.
Status
