Laptop options
shteii01
Joined Feb 19, 2010
4,644
So how do you scroll on a trackpad without a wheel? :confused:
On my Acer Aspire One the scroll function is the right edge of the trackpad . You just move your finger along the right edge, and that works same as scrolling wheel.
Regarding the tap for left click, someone wrote earlier that just putting finger on the pad would act like a click and they could not stand it. I think the solution is that multifunction trackpads come with a small utility program where you can adjust the behavior of the trackpad. Obviously just touching the pad should not activate left click so the sensitivity of the pad needs to be adjusted.
cmartinez
Joined Jan 17, 2007
8,759
Late to the thread... but #12, whatever you decide on (if it's not too late already) try to max the RAM capability of your laptop, either before or after you buy it. It improves performance significantly. You won't regret it.
strantor
Joined Oct 3, 2010
6,875
Someone mentioned
Some of the larger laptops have two bays so you can have two storage devices. Can do hd+hd or ssd+hd or ssd+ssd.
Remember. CD rom drive are almost dead now so the cases now have space for second drive, ssd or hd.
I bought a Sony Vaio in 2006 that had 2 drive bays.
