This video maker test some liitokala cells to see if they're genuine ....A friend of mine purchased this Liitokala batteries for his laptop.
oz93666 said:This looks to be the same battery https://www.ebay.co.uk/itm/4Pcs-340...571863?hash=item4d944d3dd7:g:7AkAAOSw5QJc3tn-
These look OK , identical to the ones on Ebay ... 20 reviews on aliex , someone has tested capacity and says they're good ...I'm looking at this but can you guys tell me what you think? Is it a fake cell?
https://www.aliexpress.com/item/32975194975.html
Discharging quickly is good?These look OK , identical to the ones on Ebay ... 20 reviews on aliex , someone has tested capacity and says they're good ...
Yes they can discharge very quickly ...20A
I have some questions just to make sure:To assure continued operation when changing the cells, supply a secondary voltage of same voltage level through a 100-Ohm resistor to the circuit before disconnection. Remove the outside supply only after the circuit receives voltage again from the new cells. Furthermore, some fuel gauge chips run wires to each cell. These must be reassembled in the correct sequence beginning with cell one, then two, three and so forth.
Thrilled you saw the light after 40+ posts.Ok, apparently cells have a specific way they should be removed and re-added so that the charger controller won't get blocked. If such thing happens, probably only specialized personnel will be able to unblock the charger. Usually these people takes large amount of money to get the job done. So, if this happens, a new battery will be less expensive!
I don't understand the sarcasm, but I'll just pass it!Thrilled you saw the light after 40+ posts.
As for the rest of that stuff. Can't you just turn it off and replace the battery? Maybe you will need to reset the clock.
As for the "sarcasm," you obviously have been getting input from several sources and ignoring better advice here. What do you expect?An what clock you're talking about?
I've been trying to follow advises here and obviously from other sources because I'm not standing here just waiting for you guys to do everything for me. So I keep searching, reading, etc.As for the "sarcasm," you obviously have been getting input from several sources and ignoring better advice here. What do you expect?
As for the clock, it is a "laptop" or similar device, All of the ones I have seen have a calendar/clock function and often a separate battery to keep that function alive during power down or battery replacement. Ignoring that "keep alive" function usually means that one only needs to reset that clock/calendar after a hard restart.
Ok, I'll try to come up with a solution to keep the voltages at all points (+, Balancing spot 1, Balancing spot 2 and baancing spot 3) at the same level as before disconnecting!There is often (almost always) a battery management chip as part of the battery pack. One of the functions of the BMS is to detect if the battery has been discharged to below a certain voltage. If a Li-ion battery has been over-discharged, it is much more likely to fail catastrophically during a following charge. If you just disconnect the existing batteries, the BMS will see this as an excessively low voltage condition and disable charging as a safeguard.
Whether the low voltage detect applies to the battery as a whole, or whether it is determined on a per cell basis I can't say - it might be either depending on the BMS. And the method of resetting is also dependent on the particular BMS.
Could you please explain the reasoning behind the 100Ω resistor you're suggesting?I'd reduce R1 - R4 to 1K instead of 10K. Then add a 100 ohm resistor inline to the V+ line to the top left pair of batteries.
The 100 ohm would be to limit the current into the stack in the case where the stack voltage was significantly below your 16.4 volt source.Could you please explain the reasoning behind the 100Ω resistor you're suggesting?
Ok, thanks.The 100 ohm would be to limit the current into the stack in the case where the stack voltage was significantly below your 16.4 volt source.
