Knight Rider in PLC (Siemens Logo!) ..#2
panic mode
Joined Oct 10, 2011
5,255
so you want outputs to cycle through following sequences:
0001
0010
0100
1000
0100
0010
0001
actually you only need the first six states.
so clock, counter and decoder is all that is needed...
here is an example done in ladder but same can be done in any language.
first line is clock
second line is counter
next four lines are decoding counter values and turning on outputs.
to get different pattern, just modify decode section.
MertkanSucati
Joined Aug 27, 2021
0001
0010
0100
1000
0100
0010
0001
first line is clock
Thanks broo . you are the man. I'll try to make it
