Kitchen hood problem
Parz
Joined Sep 30, 2018
Hi i am masud,i have business of kitchen hood ,i want to know which motor,circuit and capacitor will be better for a kitchen hood long lasting
KeithWalker
Joined Jul 10, 2017
3,619
The size and type of motor will depend on a number of factors:
The volume and rate at which air is to flow.
The size of the exhaust ducting.
The type and efficiency of the blower (fan blades or centrifugal).
I suggest that you start doing some research if you want to design a successful product.
Good luck.
MaxHeadRoom
Joined Jul 18, 2013
30,828
Small motor of this type, small fans etc, are generally shaded pole motor, one thing to aid motor longevity is to protect the motor itself from oven heat and particle laden updrafts.
They are generally stepped speed by multi position switch or variable resistance Triac control.
Max.
Parz
Joined Sep 30, 2018
Can you help me that how can I understand which motor good for kitchen hood,and which circuit and capacitor is better for kitchenhood??
MaxHeadRoom
Joined Jul 18, 2013
30,828
If using a shaded pole motor it does not require a capacitor.
Use a radial fan and if possible use a ball bearing motor for longer life.
Max.
