In order to make progress I will press on, we can come back to make sure you understand what a node is.
KCL for the node A introduces the equation
\({I_1} = {I_2} + {I_3}\)
We can also write a KCL equation for node B
\({I_4} = {I_5} + {I_6}\)
But this does not introduce any new information since these are really just the branch currents at the other end of each branch.
So there are three unknowns and just one equation.
So the system cannot be solved by KCL alone.
This also brings up the points the if there are N nodes then there are (N-1) independent KCL simultaneous equations.
I have used LaTex to show the equations this time because it occurred to me that you may have thought the rubbishy capital 'I ' used by this forum was a one and hence thought I was entering values into the equations.
Using a proper Roman I will avoid this confusion.
You were also asked to identify the loops on your diagram.
I have done this in the next stage.
Again this is important because this also identifies a direction.
We need two more equations to solve the system and can get these from KVL with all these preliminaries in place.
